Executing a Procedure
There are many different ways to let AIMMS execute a procedure in your model. For example you can choose to let AIMMS execute a program when you open your project, when you open a specific page, when you click a button, or when you change a value in a table. These features are useful when making an end-user project. There are also two possibilities to execute procedures directly, which can be used for test purpose. One possibility is to select Procedure… from the Run menu and select the procedure in the dialog box that appears. The other method is to select a procedure in the model tree and select Run Procedure from the right mouse menu.
Learn more about
