Executing the Main Model
In AIMMS models executing the main model is the same as running the special procedure MainExecution. If your model has one major execution sequence (for example the solve of a mathematical program), then you can best place this in the procedure MainExecution. You can run the procedure MainExecution by simply selecting Main Model from the Run menu (or press F6).
Learn more about
