Calculation of Shadow Price Ranges
AIMMS can calculate the shadow price ranges for an LP problem:
The dual problem is given by
The shadow price range for constraint \(i\) is calculated by solving the following two problems
and
where \(D_{obj}\) denotes the optimal objective value of (D). The optimal objective value of (Smax) gives the largest shadow price and that of (Smin) the smallest shadow price for constraint \(i\).
In practice the problems (Smax) and (Smin) are sometimes infeasible because of numerical problems with the constraint
Therefore AIMMS uses the constraint
instead where \(R\) is defined as
Here \(\epsilon_r\) is the value of the option Shadow Price Range Relative Tolerance and \(\epsilon_a\) the value of the option Shadow Price Range Absolute Tolerance. Note that if both options are set to 0 (the default) then \(R = D_{obj}\), otherwise \(R > D_{obj}\).
Remark
The subproblems (Smax) and (Smin) are not solved for constraints for which the nominal right-hand- side value is in the interior of the interval
[smallest right-hand-side, largest right-hand-side]
since for these constraints it is known that
smallest shadow price = largest shadow price = shadow price.
Calculating the smallest and largest right-hand-side values is only supported by CPLEX and Gurobi, so only these solvers can skip solving some of the subproblems (Smax) and (Smin).
The option Time Limit Sensitivity Ranges can be used to set a time limit for each LP problem that is solved while calculating shadow price ranges (or variable value ranges).
Learn more about
