USER'S GUIDE
  • AIMMS Basics
  • Creating and Managing a Model
  • Data Management
  • AIMMS and Solvers
    • AIMMS IDE
      • AIMMS IDE Overview
      • Model Explorer
      • Identifier Selector
      • Page Manager
      • Template Manager
      • Menu Builder
      • Security
      • Miscellaneous
        • AIMMS Windows
        • AIMMS Files
        • AIMMS Trees
        • Layouts
        • Exporting an End User Project
        • Backups
        • Colors
        • Command Line Options
        • Grab Screen Area
        • Help files for AIMMS projects
        • Localization
        • Solver Configuration
        • XML
        • Short Descriptions
          • Child Page
          • Dialog Box
          • Forward Link
          • Reverse Link
          • Maxint
          • Start Window Menubar
          • Text Editor
          • Command Line Options - License
          • File Printing
          • User Files in the Project File
          • Deleting the Listing File
          • Updatebility of Identifiers
          • Executing a Procedure
          • Exit AIMMS
          • Closing a Window
          • Closing All Windows
          • Start Window Toolbar
          • Print Setup
          • Closing a Project
          • Saving a Project
          • Navigating the open Windows
          • Stopping Execution
          • Print
          • Compilation
          • Help on Window
          • About AIMMS Dialog Box
          • AIMMS Start Window
          • State File Manager
          • Commit Name Changes
          • Help - Contents and Index
          • Opening a Project
          • Creating a Project
          • Linking Objects
          • Different Results in NLP Runs
          • Undo Edit
          • Save As a New Page
          • Keep Page Open
          • Save a Page
          • Executing the Main Model
          • Previous Page
          • Next Page
          • Variables in GUI
          • Name Completion
          • Identifier Selection Dialog Box
          • Wizards
          • MainInitialization
          • MainExecution
          • MainTermination
          • Find & Replace
          • Find All
          • Identifier Info
          • Maximize Attribute Window
          • Insert Current Data
          • Goto Line
          • New Dataset
          • Save Case Dialog Box
          • Load Case Dialog Box
          • New Case
          • Scalar Object in User Mode
          • User Logoff
          • User Change Password
          • Installing System Modules
          • Tuning - Code Generation
          • Memory Manager - Data Area Size
          • Memory Manager - Standard Block Area Size
          • Memory Manager - Static Area Size
          • Memory Manager - Work Area Size
          • Calculation of Shadow Price Ranges
          • Parent Page
          • Generate Public/Private Key Pair
        • Multi Development
      • Diagnostic Tools
      • Options
    • Solvers
  • Miscellaneous
User's Guide
AIMMS Logo
  • User's Guide »
  • AIMMS and Solvers »
  • AIMMS IDE »
  • Miscellaneous »
  • Short Descriptions »
  • Print Setup
  • Edit on Github
Print Setup
If you select Print Setup from the File menu, a standard Windows dialog box will appear in which you can select the current printer. Although you can also specify many other printer properties in this dialog, AIMMS will ignore most of them, because when printing pages or text files, AIMMS will use the settings specified in the Print Template or the Text Printing dialog box, respectively.
Last updated: Aug 06, 2025
Help & Feedback
Docs
Edit this page to fix an error or add an improvement in a pull request
Create an issue to suggest an improvement to this page
Product
Create a topic if there's something you don't like about this feature
Propose functionality by submitting a feature request
Support
Not what you where looking for? Search the docs
Remember we also have Community support
Still having trouble? Reach out to us
Next Previous
AIMMS Logo
Disclaimer Privacy Policy © 1989 - 2026 AIMMS B.V.
