Quick Start to Using Benders’ Decomposition
System module
The system module with the name GMP Benders Decomposition implements
the Benders’ decomposition algorithm. You can add this module to your
project using the Install System Module command in the AIMMS
Settings menu. This module contains three procedures that can be
called, each implementing a different algorithm.
Classic algorithm
The procedure DoBendersDecompositionClassic inside this module
implements the classic version of the Benders’ decomposition algorithm,
in which the master problem and the subproblem are solved in an
alternating sequence.
Modern algorithm
The procedure DoBendersDecompositionSingleMIP inside the module
implements the modern approach for MIP problems which solves only a
single MIP problem; the subproblem is solved whenever the MIP solver
finds a solution for the master problem (using callbacks).
Two phase algorithm
The procedure DoBendersDecompositionTwoPhase inside the module
implements a two phase algorithm for MIP problems. In the first phase it
solves the relaxed problem (in which the integer variables become
continuous) using the classic Benders decomposition algorithm. The
Benders’ cuts found in the first phase are then added to the master
problem in the second phase after which the MIP problem is solved using
either the classic or modern approach of the Benders decomposition
algorithm.
The procedure DoBendersDecompositionClassic has two input arguments:
MyGMP, an element parameter with rangeAllGeneratedMathematicalPrograms, andMyMasterVariables, a subset of the predefined setAllVariablesdefining the variables in the master problem.
For a MIP problem, the integer variables typically become the variables
of the master problem, although it is possible to also include
continuous variables in the set of master problem variables. The
DoBendersDecompositionClassic procedure is called as follows:
generatedMP := GMP::Instance::Generate( SymbolicMP );
GMPBenders::DoBendersDecompositionClassic( generatedMP, AllIntegerVariables );
Here SymbolicMP is the symbolic mathematical program containing the
MIP model, and generatedMP is an element parameter in the predefined
set AllGeneratedMathematicalPrograms. GMPBenders is the prefix
of the Benders’ module. The implementation of this procedure will be
discussed in Benders’ Decomposition - Textbook Algorithm.
The procedure DoBendersDecompositionSingleMIP has the same input
arguments as the procedure DoBendersDecompositionClassic. The
DoBendersDecompositionSingleMIP procedure is called as follows:
GMPBenders::DoBendersDecompositionSingleMIP( generatedMP, AllIntegerVariables );
This procedure can only be used if the original problem contains some integer variables. The implementation of this procedure will be discussed in Implementation of the Modern Algorithm.
The procedure DoBendersDecompositionTwoPhase has one additional
argument compared to the procedure DoBendersDecompositionClassic.
Namely, the third argument UseSingleMIP is used to indicate whether
the second phase should use the classic algorithm (value 0) or the
modern algorithm (value 1). The procedure is called as follows if the
modern algorithm should be used:
GMPBenders::DoBendersDecompositionTwoPhase( generatedMP, AllIntegerVariables, 1 );
This procedure should only be used if the original problem contains some integer variables. The implementation of this procedure will be discussed in Implementation of the Two Phase Algorithm.
Combining procedure
To make it easier for you to switch between the three algorithms, the
module also implements the procedure DoBendersDecomposition that
calls one of the three procedures above based on the Benders’ mode. The
first two arguments of this procedure are the same as before, namely
MyGMP and MyMasterVariables. The third argument,
BendersMode, is an element parameter that defines the Benders’ mode
and can take value 'Classic', 'Modern', 'TwoPhaseClassic' or
'TwoPhaseModern'. The procedure is called as follows if the two
phase algorithm should be used with the modern algorithm for the second
phase:
GMPBenders::DoBendersDecomposition( generatedMP, AllIntegerVariables,
'TwoPhaseModern' );
If the problem contains no integer variables then only mode
'Classic' can be used.
Control parameters
The Benders’ module defines several parameters that influence the Benders’ decomposition algorithm. These parameters have a similar functionality as options of a solver, e.g., CPLEX. The most important parameters, with their default setting, are shown in this table.
Parameter |
Default |
Range |
Subsection |
1e-6 |
[0,1] |
1e7 |
{1,maxint} |
1e9 |
[0,inf) |
0 |
{0,1} |
0 |
{0,1} |
1 |
{0,1} |
1 |
{0,1} |
1 |
{0,1} |
1 |
{0,1} |
0 |
{0,1} |
0 |
{0,1} |
The parameters that are not self-explanatory are explained in Control Parameters That Influence the Algorithm; the last column in the table refers to the subsection that discusses the corresponding parameter.
Optimality tolerance
The optimality tolerance, as controlled by the parameter
BendersOptimalityTolerance, guarantees that a solution returned by
the Benders’ decomposition algorithm lies within a certain percentage of
the optimal solution.
Solver options
The parameters BendersOptimalityTolerance, IterationLimit and
TimeLimit are used by the classic algorithm (and the first phase of
the two phase algorithm). For the modern algorithm, the corresponding
general solver options, MIP_relative_optimality_tolerance,
iteration_limit and time_limit respectively, are used.
