Implementation of the Two Phase Algorithm
First phase
The Benders’ module also implements a two phase algorithm for MIP problems. In the first phase it solves the relaxed problem in which the integer variables become continuous. The resulting relaxed MIP problem is then solved using the classic Benders’ decomposition algorithm in order to find Benders’ cuts.
Second phase
The second phase solves the original MIP problem. The master problem created in the first phase is also used in the second phase but without relaxing the integer variables. The Benders’ cuts that were added during the first phase are not removed; these cuts are still valid. In general the relaxed MIP problem can be solved more efficiently than the MIP problem using Benders’ decomposition, and the hope is that by adding the Benders’ cuts found during the first phase, the Benders’ decomposition algorithm needs considerably less iterations in the second phase to solve the original MIP problem.
Implementation of DoBendersDecompositionTwoPhase
The procedure DoBendersDecompositionTwoPhase implements the two
phase algorithm. It starts by making copies of its first two input
arguments. Next the master problem and the subproblem are created. The
parameters for the number of optimality and feasibility cuts are reset.
The problem type of the master problem is changed from ‘MIP’ to ‘RMIP’
which basically changes the integer variables into continuous variables.
The procedure BendersAlgorithm then solves the relaxed problem using
the classic Benders’ decomposition algorithm; see
Implementation of the Classic Algorithm for its implementation. After checking
the program status of the relaxed master problem the algorithm continues
by switching the problem type of the master problem back to ‘MIP’. Next
the original problem is solved using either procedure
BendersAlgorithmSingleMIP (Implementation of the Modern Algorithm) or
BendersAlgorithm (Implementation of the Classic Algorithm). The algorithm
ends by deleting the master problem and the subproblem. As before we
leave out parts of the code that handle details like creating a status
file, for the sake of brevity and clarity.
OriginalGMP := MyGMP ;
VariablesMasterProblem := MyMasterVariables ;
! Create (Relaxed) Master problem.
gmpM := GMP::Benders::CreateMasterProblem( OriginalGMP, VariablesMasterProblem,
'BendersMasterProblem',
feasibilityOnly : FeasibilityOnly,
addConstraints : AddTighteningConstraints ) ;
! Create Subproblem.
gmpS := GMP::Benders::CreateSubProblem( OriginalGMP, gmpM, 'BendersSubProblem',
useDual : UseDual,
normalizationType : NormalizationType );
solsesS := GMP::Instance::CreateSolverSession( gmpS ) ;
NumberOfOptimalityCuts := 0;
NumberOfFeasibilityCuts := 0;
! Start the classic Benders' decomposition algorithm for the relaxed Master
! MIP problem.
GMP::Instance::SetMathematicalProgrammingType( gmpM, 'RMIP' );
IterationLimit := IterationLimitPhaseSingle;
BendersAlgorithm;
ProgramStatus := GMP::Solution::GetProgramStatus( OriginalGMP, 1 );
if ( ProgramStatus = 'Infeasible' or
ProgramStatus = 'Unbounded' ) then
DoPhaseTwo := 0;
endif;
if ( DoPhaseTwo ) then
! Switch back math program type.
GMP::Instance::SetMathematicalProgrammingType( gmpM, 'MIP' );
if ( UseSingleMIP ) then
! Start the Single MIP Tree Benders' decomposition algorithm.
BendersAlgorithmSingleMIP;
else
IterationLimit := IterationLimitPhaseTwo;
BendersAlgorithm;
endif;
endif;
GMP::Instance::Delete( gmpM );
GMP::Instance::Delete( gmpS );
Iteration and time limit
The section in the Benders’ module for the two phase algorithm contains
two extra control parameters for setting the iteration and time limit
used by the classic Benders’ decomposition algorithm in the second
phase. These parameters are IterationLimitPhaseTwo and
TimeLimitPhaseTwo respectively. The parameters IterationLimit
and TimeLimit are used in the first phase. In some cases it might be
a good strategy to limit the number of iterations (or the running time)
during the first phase. The two phase algorithm will then still find a
global optimal solution of the original problem as long as the second
phase terminates normally. If the modern approach (with a single MIP
tree) is used in the second phase then the general solver options
iteration_limit and time_limit are used for the second phase.
