Guidelines for working with library projects
Identifying independent tasks
Unless you started using library projects from scratch, you need to convert the contents of your AIMMS project as soon as you decide to divide the project into multiple library projects. The first step in this process is to decide which logical tasks in your application you can discern that meet the following criteria:
the task represents a logical unit within your application that is rather self-contained and can possible be shared with other AIMMS projects,
the task can be comfortably and independently worked on by a separate developer or developer team, and
the task provides a limited interface to the main application and/or the other tasks you have identified.
Good examples of generic tasks that meet these criteria are the tasks listed on Collaborative Project Development. Once your team of developers agrees on the specific tasks that are relevant for your application, you can set up a library project for each of them.
Library interface…
The idea behind library projects is to be able to minimize the interaction between the library, the main project and other library projects. At the language level AIMMS supports this by letting you define an interface to the library, i.e. the set of public identifiers and procedures through which the outside world is allowed to connect to the library. Library identifiers not in the interface are strictly private and cannot be referenced outside of the library. The precise semantics of the interface of a library module is discussed in LibraryModule Declaration and Attributes of the Language Reference.
… used in model and GUI
This notion of public and private identifiers of a library module does not only apply to the model source itself, but also propagates to the end-user interface. Pages defined in a library can access the library’s private identifiers, while paged defined outside of the library only have access to identifiers in the interface of the library.
Minimal dependency
The concept of an interface allows you to work independently on a library. As long as you do not change the declaration of the identifiers and procedures in its interface, you have complete freedom to change their implementation without disturbing any other project that uses identifiers from the library interface. Similarly, as long as a page or a tree of pages defined in a library project is internally consistent, any other project can add a reference to such pages in its own page tree. Pages outside of the library can only refer to identifiers in the library interface, and hence are not influenced by changes you make to the library’s internal implementation.
Conversion to library projects
If your application already contains model source and pages associated with the tasks you have identified in the previous step, the next step is to move the relevant parts of your AIMMS project to the appropriate libraries. You can accomplish this by simply dragging the relevant nodes or subtrees from any of the trees tree in the main project to associate tree in a library project. What should remain in the global project are the those parts of the application that define the overall behavior of your application and that glue together the functionality provided by the separate library projects.
