The OPTION and PROPERTY Statements
Options
Options are directives to AIMMS or to the solvers to execute a task in a
particular manner. Options have a name and can assume a value that is
either numeric or string-valued. You can modify the value of an option
from within the graphical interface. The assigned value is stored along
with the project. All global options are set to their stored values at
the beginning of each session. During execution you can change option
settings using the OPTION statement.
Syntax
option-statement:
You can find a complete list of global options for AIMMS and its solvers in the help system.
Option values
The right-hand side of an OPTION statement must be a scalar
expression of the proper type. If the option expects a string value,
AIMMS will accept both string- or element-valued expressions. An example
follows.
option Bound_Tolerance := 1.0e-6,
Iteration_Limit := UserSettings('IterationLimit');
Solver options
Some solver options are available for more than one solver. If you
modify such a solver option per se, AIMMS will modify the option for all
solver that support it. If you want to restrict the change to only a
single solver, you can prefix the option name by the name of the solver
followed by a dot ., as illustrated in the example below.
option 'Cplex 22.1'.lp_method := 'dual simplex';
This statement will set the option lp_method of the solver that is
known to the system as 'Cplex 22.1' equal to 'dual simplex'. The
solver name can be either a quoted solver name, or an element parameter
into the predefined set AllSolvers.
Identifier properties
Identifier properties can be turned on or off. All properties
default to off, unless they are turned on-either in the declaration
of the identifier or in a PROPERTY statement. During the execution
of your model you can dynamically change the default values of
properties through the PROPERTY execution statements.
Syntax
property-statement:
Resetting properties
The properties of all identifier types can be found in the identifier
declaration sections. Not all property settings can be changed, e.g. you
cannot dynamically change the Input or Output property of
arguments of functions and procedures. In such cases, AIMMS will produce
a runtime error. An example of the PROPERTY statement follows.
if ( Card(Cities) > 100 ) then
property IntermediateTransport.NoSave := on;
endif;
Once the set of Cities contains more than 100 elements, the
identifier IntermediateTransport is no longer saved as part of a
case file.
Multiple identifiers
When the PROPERTY statement is applied to an index into a subset of
the predefined set AllIdentifiers, AIMMS will change the
corresponding property for all identifiers in that subset.
Example
The following example illustrates how the PROPERTY statement can be
used to obtain additional sensitivity data for a set
SensitivityVariables of (symbolic) variables that has been
previously determined.
for ( var in SensitivityVariables ) do
property var.CoefficientRanges := on;
endfor;
Here, you request AIMMS to determine the smallest and largest values for
the objective coefficient of each variable in SensitivityVariables
during the execution of a SOLVE statement such that the optimal
basis remains constant (see also Variable Properties).
