Node Declaration and Attributes
Node attributes
Each node in a network has a number of associated incoming and outgoing
flows. Unless stated otherwise, these flows should be in balance. Based
on the flows specified in the model, AIMMS will automatically generate a
balancing constraint for every node. The possible attributes of a
Node declaration are given in this table.
| Attribute | Value-type | See also page |
 | index-domain | The Parameter IndexDomain attribute, The Variable IndexDomain attribute, The Constraint IndexDomain attribute |
 | unit-valued expression | |
 | string | |
 | comment string | |
 | expression | |
 | The Parameter Property attribute, The Variable Property attribute, The Constraint Property attribute |
Nodes are like constraints
Nodes are a special kind of constraint. Therefore, the remarks in
Constraint Declaration and Attributes that apply to the attributes of constraints are
also valid for nodes. The only difference between constraints and nodes
is that in the definition attribute of a node you can use one of the
keywords NetInflow and NetOutflow.
The keywords NetInflow and NetOutflow denote the net input or
net output flow for the node. The expressions represented by
NetInflow and NetOutflow are computed by AIMMS on the basis of
all arcs that depart from and arrive at the declared node. Since these
keywords are opposites, you should choose the keyword that makes most
sense for a particular node.
Example
The following two Node declarations show natural applications of the
Node CustomerDemandNode {
    IndexDomain  : (j in Customers, p in Products);
    Definition   : {
        NetInflow >= ProductDemanded(j,p)
Node DepotStockSupplyNode {
    IndexDomain  : (i in Depots, p in Products);
    Definition   : {
        NetOutflow <= StockAvailable(i,p) + ProductImport(i,p)
The declaration of CustomerDemandNode(c,p) only involves network
flows, while the flow balance of DepotStockSupplyNode(d,p) also uses
a variable ProductImport(d,p).
