Introduction to XML Support in AIMMS
XML support in AIMMS
In order to help you understand the XML support available within AIMMS to its full extent, this section provides an explanation of the basic concepts used in XML. If you are already familiar with XML and XML schemas, the material in this section may help you to understand how the XML concepts you are already familiar with are used by the XML facilities in AIMMS.
The XML data format
The XML data format is a text format built around just two syntactical components, elements and attributes. Because the semantics of these components are not fixed and can be user-defined, the XML data format can be used to represent virtually any meaningful concept.
XML elements
XML elements are denoted by a start tag (a word identifying the type
of element enclosed by the < and > characters) and an end
tag (the same element type enclosed by the </ and >
characters). Elements delimit the piece of XML data between its start
and end tag. Elements may hold only text or numeric data, or they can
provide depth to XML data, since the enclosed XML data may contain other
XML elements. An element in a stream of XML data is, in fact, a node in
the tree associated with the entire stream of XML data. The root node of
this tree corresponds to the obligatory and unique root element of the
XML data stream.
XML elements without content
If an element does not contain any enclosed XML content, it is possible
to omit the end tag alltogether, and enclose the start tag between
< and /> characters. This format is commonly used if the
element contains only attributes.
XML attributes
XML attributes provide additional information about a particular
element in an XML data stream. Attributes are specified by the form
name="value between the “< and > (or />)
characters of the start tag of the element in question.
The Data Reconciliation example
All examples in this chapter make use of a single AIMMS project that comes with the AIMMS system, the Data Reconciliation project. In this example, flows between units in a chemical plant, as well the chemical composition of these flows, are measured. Unfortunately, such measurements might not be internally consistent despite, for instance, a physical requirement that the sum of all flows into any unit be equal to the sum of all flows out of that unit (i.e. no material is created or lost within a unit). Due to the inaccuracy of the measurement devices (or, even worse, broken measurement devices), the measured values do not necessarily satisfy such balances. The objective of the model is to find a set of flow values and compositions which are internally consistent, and lie as close as possible to the corresponding measured values. Such consistent values are called reconciled values. Within the model the measured and reconciled values are stored in the identifiers
MeasuredFlow(f),MeasuredComposition(f,c),Flow(f), andComposition(f,c),
where f is an index into a set of Flows, and c is an index
into a set of Components. this table contains
the measured and reconciled flow values and compositions used throughout
this chapter.
Flow name |
Measured values |
Flow value [ton/h] |
Flow composition [%] |
\(N_2\) |
\(H_2\) |
\(NH_3\) |
\(Ar\) |
Inflow |
111.98 |
26.96 |
72.71 |
0.33 |
Mix |
24.56 |
4.91 |
NH3-Mix |
19.99 |
NH3-Flow |
105.59 |
Residue |
69.68 |
Ar-Flow |
Feedback |
358.00 |
Flow name |
Reconciled values |
\(N_2\) |
\(H_2\) |
\(NH_3\) |
\(Ar\) |
Inflow |
117.03 |
26.96 |
72.71 |
0.00 |
0.33 |
Mix |
475.03 |
23.95 |
71.08 |
0.05 |
4.91 |
NH3-Mix |
475.03 |
19.99 |
59.08 |
15.27 |
5.66 |
NH3-Flow |
105.59 |
0.00 |
0.00 |
100.00 |
0.00 |
Residue |
369.44 |
23.57 |
69.68 |
0.07 |
6.67 |
Ar-Flow |
11.44 |
89.19 |
0.00 |
0.00 |
10.81 |
Feedback |
358.00 |
22.82 |
70.48 |
0.07 |
6.62 |
XML data example
The XML fragment below illustrates a possible XML format to store the
measured and reconciled flows and compositions. The root element
FlowMeasurementData has a date attribute to indicate the date of
the measurements. The root element contains one or more Flow
elements which contain the measured (if any) and reconciled flow values
for all the flows in the network. Each Flow element contains a
single Composition element, which, in turn, contains one or more
Component elements with the measured (if any) and reconciled
composition values for each component of the flow in question.
<FlowMeasurementData xmlns="http://www.aimms.com/Reconciliation" date="2001-10-01">
<Flow name="Inflow" measured="111.98" reconciled="117.03">
<Composition>
<Component name="N2" measured="26.96" reconciled="26.96"/>
<Component name="H2" measured="72.71" reconciled="72.71"/>
<Component name="Ar" measured="0.33" reconciled="0.33"/>
</Composition>
</Flow>
<Flow name="Mix" reconciled="475.03">
<Composition>
<Component name="N2" measured="24.56" reconciled="23.95"/>
<Component name="H2" reconciled="71.08"/>
<Component name="NH3" reconciled="0.05"/>
<Component name="Ar" measured="4.91" reconciled="4.91"/>
</Composition>
</Flow>
<Flow name="NH3-Mix" reconciled="475.03">
<Composition>
<Component name="N2" measured="19.99" reconciled="19.99"/>
<Component name="H2" reconciled="59.08"/>
<Component name="NH3" reconciled="15.27"/>
<Component name="Ar" reconciled="5.66"/>
</Composition>
</Flow>
<Flow name="NH3-Flow" measured="105.59" reconciled="105.59">
<Composition>
<Component name="NH3" reconciled="100.00"/>
</Composition>
</Flow>
<Flow name="Residue" reconciled="369.44">
<Composition>
<Component name="N2" reconciled="23.57"/>
<Component name="H2" measured="69.68" reconciled="69.68"/>
<Component name="NH3" reconciled="0.07"/>
<Component name="Ar" reconciled="6.67"/>
</Composition>
</Flow>
<Flow name="Ar-Flow" reconciled="11.44">
<Composition>
<Component name="N2" reconciled="89.19"/>
<Component name="Ar" reconciled="10.81"/>
</Composition>
</Flow>
<Flow name="Feedback" measured="358.00" reconciled="358.00">
<Composition>
<Component name="N2" reconciled="22.82"/>
<Component name="H2" reconciled="70.48"/>
<Component name="Ar" reconciled="6.62"/>
</Composition>
</Flow>
</FlowMeasurementData>
Not unique
The XML data format illustrated above is not unique. For instance, the
measured and reconciled values could have been represented by child
elements of the Flow and Component elements instead of by
attributes. Thus, a different, but equally valid, XML representation of
the same data is illustrated in the XML data snippet below.
<Flow name="Inflow">
<MeasuredValue>111.984</MeasuredValue>
<ReconciledValue>117.034</ReconciledValue>
<Composition>
<Component name="N2">
<MeasuredValue>26.960</MeasuredValue>
<ReconciledValue>26.960</ReconciledValue>
</Component>
</Composition>
</Flow>
The particular XML data format chosen may be a matter of taste, or the result of a formal agreement between several parties who wish to use the corresponding XML data.
XML schema
To support you in defining a particular XML data format in a formal manner, XML provides an XML-based standard to specify such definitions. This standard is called XML Schema. It allows you, among other things, to specify
the allowed (tree) structure of a particular XML data format in terms of all possible elements and their child elements,
the minimum and maximum number of times a particular element can occur,
which attributes are supported by particular elements,
whether attributes are optional or required, and
the intended data types of elements and attributes in your XML data format.
To create an XML schema file that matches an intended XML data format, it is best to use one of the tools available for this purpose. For more detailed information about XML schema, as well as the tools available for creating an XML schema file, refer to this page.
XML schema example
The following XML schema definition, formally defines the XML data format as used in the XML data example above.
<xs:schema targetNamespace="http://www.aimms.com/Reconciliation"
xmlns:xs="http://www.w3.org/2001/XMLSchema"
elementFormDefault="qualified" attributeFormDefault="unqualified">
<xs:element name="FlowMeasurementData">
<xs:complexType>
<xs:sequence>
<xs:element name="Flow" maxOccurs="unbounded">
<xs:complexType>
<xs:sequence>
<xs:element name="Composition" minOccurs="0">
<xs:complexType>
<xs:sequence>
<xs:element name="Component" maxOccurs="unbounded">
<xs:complexType>
<xs:attribute name="name" type="xs:string" use="required"/>
<xs:attribute name="measured" type="xs:double" use="optional"/>
<xs:attribute name="reconciled" type="xs:double" use="optional"/>
</xs:complexType>
</xs:element>
</xs:sequence>
</xs:complexType>
</xs:element>
</xs:sequence>
</xs:complexType>
</xs:element>
</xs:sequence>
<xs:attribute name="date" type="xs:date" use="required"/>
</xs:complexType>
</xs:element>
</xs:schema>
Schema namespaces
An XML schema definition can specify a namespace by which the schema is
to be known. In the example above, the targetNamespace attribute of
the xs:schema element specifies that the schema that follows defines
the namespace http://www.aimms.com/XMLSchema/ReconciliationExample.
In the XML data example listed earlier in this section, the xmlns
attribute of the root element specifies that all element and attribute
names underneath the root element are to be interpreted in the context
of that namespace.
Two modes of XML support
AIMMS allows you to read and write XML data from within your model in two modes:
it lets AIMMS generate and read XML data based on identifier definitions in your model, or
it lets AIMMS generate and read XML data according to a given XML schema specification.
AIMMS-generated XML
In the first mode, AIMMS will generate and read XML for the subset of identifiers that you specify. The format of the generated XML closely resembles the declaration of the identifiers in your model, generates XML data for one identifier at a time, and adds a tree level for each dimension. Letting AIMMS generate XML data for your model is the fastest way of getting XML data that corresponds to your model, but
gives you little control over the final result, and
programs that use the generated XML data have to adhere to the generated format.
User-defined XML
In the second mode, AIMMS assumes that you already have a XML schema file that specifies the precise XML data format that you want to generate from within AIMMS, or want to read from an external XML data file. AIMMS provides a tool to let you map the elements and attributes in the XML schema onto sets and multidimensional identifiers in your model. Based on this mapping, and the data in your model, you can let AIMMS generate XML data according to the specified schema, or let AIMMS fill the corresponding identifiers according to an XML data file in the specified format.
