Unit Expressions
Unit expressions
Unit expressions can be used at various places in an AIMMS model, such as:
the
BaseUnitattribute of aQuantitydeclaration (defined in The Quantity Declaration),in a local unit override of a numerical (sub-)expression (discussed in Locally Overriding Units)
in a convention list of the
PerUnit,PerQuantityorPerIdentifierattributes of aConvention(see also Globally Overriding Units Through Conventions), oron the right hand side of an assignment to a unit parameter (see Unit-valued Parameters).
The syntax of a unit expression is straightforward, and given below.
Syntax
unit-expression:
Unit symbols and references
The simplest form of unit expression is just a unit symbol, as defined
in either the BaseUnit or the Conversion attribute of a
Quantity declaration. A reference to either a (scalar or indexed)
unit parameter (see Unit-valued Parameters) or to the .Unit
suffix of any identifier with an associated unit (see
Associating Units with Model Identifiers), is a second form of unit expression.
Unit operators and functions
More complex unit expressions can be obtained by applying the binary
unit operators *, / and ^, with the usual left-to-right
evaluation order. The following rules apply:
the operand on the right of the
*operator must be a unit expression, while the operand on the left can either be a unit expression or a numerical expression (expressing a numeric scale factor),both operands of the
/operator must be unit expressions, andthe operand on the left of the
^operator must be a unit expression, while the exponent operand must be an integer numerical expression.
In addition, AIMMS supports a number of unit functions, which can create new unit values or construct associated unit values from a given unit expression (see Unit-valued Functions).
Three types of unit expressions
However, AIMMS requires that any unit expressions uniquely falls into one of the three categories
unit constant,
simple unit expression, or
computed unit expression.
Unit constants
Unit constants are unit expressions which consist solely of unit
symbols, scalar constants and the three unit operators *, / and
^. Unit constants can be used in
the
BaseUnitattribute of aQuantity,the lists associated with a
Convention, andthe unit-valued function
Unit.
In addition, unit constants can be
displayed and entered via the AIMMS graphical user interface,
assigned to unit parameters through data statements (see Format of Text Data Files), and
exchanged with external data sources via the
READandWRITEstatements (see The READ and WRITE Statements).
Simple unit expressions
Simple unit expressions are an extension of unit constants. They are
unit expressions which consist solely of unit symbols, unit references
without indexing, scalar constants and the three unit operators *,
/ and ^. Simple unit expressions can be used in
local unit overrides, and
assignments to unit parameters.
Computed unit expressions
Computed unit expression can use the full range of unit expressions,
with the exception of unit constants. If you want to refer to unit
constants within the context of a computed unit expression, you must
embed it within a call to the function Unit, discussed in the next
section. Computed unit expressions can be used
in assignments to unit parameters, and
as an argument of the functions
ConvertUnit,AtomicUnitandEvaluateUnit(see Unit-valued Functions and Converting Unit Expressions to Numerical Expressions).
Unit-valued functions
AIMMS supports the following unit-valued functions:
Unit(unit-constant)StringToUnit(unit-string)AtomicUnit(unit-expr)ConvertUnit(unit-expr, convention)
The function Unit
The function Unit simply returns its argument, which must be a unit
constant. The function Unit is available to allow the usage of unit
constants within computed unit expressions (as discussed in the previous
section).
The function StringToUnit
The function StringToUnit converts a string, which represents a unit
expression, to the corresponding unit value. You can use this function,
for instance, after reading external string data that needs to be
converted to real unit values for further use in your model.
The function AtomicUnit
With the function AtomicUnit you can retrieve the atomic unit
expression corresponding to the unit expression passed as the argument
to the function. Thus, the unit expression
AnIdentifier.Unit / AtomicUnit(AnIdentifier.Unit)
will result in a (unitless) unit value that exactly represents the scale
factor between the unit of an identifier and its associated atomic unit
expression. You can obtain the corresponding numerical value, to be used
in numerical expressions, by applying the function EvaluateUnit
discussed in the next section.
The function ConvertUnit
The function ConvertUnit returns the unit value corresponding to the
unit expression of the first argument, but taking into consideration the
convention specified in the second argument. If the first argument
contains a reference to a .Unit suffix, AIMMS will apply the full
range of conversions including those specified in the PerIdentifier
attribute of the convention.
Examples
The expression
ConvertUnit(AnIdentifier.Unit, ConventionUsed)
returns the associated unit of the identifier AnIdentifier as if the
convention ConventionUsed were active. A further example of the use
of the function ConvertUnit is given in Unit-based Scaling of Mathematical Programs.
Numeric value of a unit expression
Although numerical values and unit values are two very distinct data types in AIMMS, the distinction between the two in real life applications is not always as strict. For instance, in the previous section the computation of the ratio between a unit and its associated atomic unit expression returned a unit value, which represents nothing more than a (unitless) scale factor. In practice, however, it is the numeric scale factor value that is of interest, and can be used in numerical computations.
The function EvaluateUnit
Using the function EvaluateUnit you can compute the numerical value
associated with a computed unit expression. Its syntax is:
EvaluateUnit(computed-unit-expression)
The numeric function value precisely corresponds to one unit of the specified computed unit expression, measured in the evaluated unit of its argument.
Example
The following assignment to the scalar parameter ScaleFactor
computes the (unitless) scale factor between the unit of an identifier
and its associated atomic unit expression.
ScaleFactor := EvaluateUnit( AnIdentifier.Unit / AtomicUnit(AnIdentifier.Unit) );
Extension of local overrides
As you will see in the next section, the function EvaluateUnit
offers extension the local unit override capability. The argument of
EvaluateUnit can be a computed unit expression (see
Unit Expressions), whereas local unit overrides can only accept
simple unit expressions.
