Unit-valued Parameters
Parametrized units
In some cases not all entries of an indexed identifier have the same associated unit. An example is the diet model where the nutritive value of each nutrient for a single serving of a particular food type is measured in a different unit.
Unit-valued parameters
In order to deal with such situations, AIMMS allows the declaration of (indexed) unit-valued parameters which you can use in the unit definition of the other parameters and variables in your model. In the model tree, unit-valued parameters are available as a special type of parameter declaration, with attributes as given in this table.
Attribute |
Value-type |
See also page |
index-domain |
quantity |
unit-expression |
string |
comment string |
unit-expression |
The Quantity attribute
You should specify the Quantity attribute if all unit values stored
in the unit parameter can be associated with a single quantity declared
in your model. The effect of specifying a quantity in the Quantity
attribute of a unit parameter is twofold:
during assignments to the unit parameter, AIMMS will verify whether the assigned unit values are commensurate with the base unit of specified quantity, and
AIMMS will modify its (compile-time) unit analysis to use the specified quantity rather than an artificial quantity based on the name of the unit parameter (see below).
The Default and Definition attributes
The Default and Definition attributes of a unit parameter have
the same purpose as the Default and Definition attribute of
ordinary parameters, except that the resulting values must be unit
expressions (see Unit Expressions). If you have specified a
quantity in the Quantity attribute, AIMMS will verify that these
unit expressions are commensurate with the specified quantity.
Allowed unit values
All unit values read from an external data source, or assigned to a unit
parameter, either via an assignment or through its Definition
attribute, must evaluate to existing unit symbols only. A compile- or
runtime error will occur, when a unit value refers to a unit symbol that
is not defined in any of the Quantity declarations contained in your
model.
Use of unit parameters
With unit parameters you can create, store and manipulate scalar or multidimensional collections of unit values. The unit values stored in a unit parameter can be used, for instance:
to associate a parametrized (i.e. multidimensional) collection of units with a single multidimensional identifier (through its Unit attribute), or
to specify a local unit override based on a unit (or collection of units) that is not known a priori.
Unit analysis…
When a Unit attribute of an identifier contains a reference to a unit parameter, this can, but need not, modify the way in which AIMMS conducts its usual unit analysis. There are two distinct scenarios, both described below.
…with associated quantity
If the unit parameter has an associated quantity (specified through its
Quantity attribute), all units stored in the unit parameter are
known to be commensurate with the base unit of the quantity, although
the individual scale factors may be different if the unit parameter is
multidimensional. In this case, AIMMS will base its unit analysis on the
associated quantity.
…without associated quantity
If there is no associated quantity, AIMMS will introduce an artificial quantity solely on the basis of the symbolic name of the unit parameter (i.e. without consideration of its dimension), and base all further unit analysis on this artificial quantity only. If there is unit consistency at the level of these artificial quantities, this automatically ensures, for multidimensional unit parameters, unit consistency at the individual level as well, regardless of the specific individual unit values stored in it.
Example
Consider the following declarations of unit-valued parameters, where
f is an index into the set Foods and n an index into the set
Nutrients.
UnitParameter NutrientUnit {
IndexDomain : n;
UnitParameter FoodUnit {
IndexDomain : f;
With these unit-valued parameters you can specify meaningful indexed unit expressions for the Unit attribute of the following parameters.
Parameter NutritiveValue {
IndexDomain : (f,n);
Unit : NutrientUnit(n)/FoodUnit(f);
Parameter NutrientMinimum {
IndexDomain : n;
Unit : NutrientUnit(n);
Variable Serving {
IndexDomain : f,
Unit : FoodUnit(f);
With these declarations, you can now easily verify that all terms in the definition of the following constraint are unit consistent at the symbolic level.
Constraint NutrientRequirement {
IndexDomain : n;
Definition : sum[ f, Servings(f)*NutritiveValue(f,n) ] >= NutrientMinimum(n);
Indexed scaling
When the Unit attribute of an identifier is parametrized by means of indexed unit parameter, AIMMS will correctly scale all data exchange with external components (see Unit-based Scaling). During data exchange with an external component, AIMMS considers the specified units at the individual (indexed) level, and will determine the proper scaling for every individual index position. In addition, when a unit convention is active, AIMMS will scale all individual entries according to that convention, as applied to the corresponding individual entries of the indexed unit parameter. As usual, all data of an identifier with a parametrized associated unit will be stored internally in the corresponding atomic unit of every individual index value.
Example revisited
When AIMMS generates mathematical program which contains the variable
Serving(f), each column corresponding to this variable will be
scaled according to the scale factor of the particular unit stored in
FoodUnit(f) with respect to their corresponding atomic unit
expressions. Similarly, AIMMS will scale the columns corresponding to
the constraint NutrientRequirement(n) according the scale factors of
the units stored in NutrientUnit(n) with respect to their
corresponding atomic unit expressions.
Initializing unit-valued parameters
You can initialize a unit-valued parameter through lists, tables, and composite tables like you can initialize any other AIMMS parameter (see Format of Text Data Files). The values of the individual entries must be valid unit constants (see Unit Expressions), and must be surrounded by square brackets. For compound units constants you can optionally indicate the associated quantity in a similar way as in the unit definition of a parameter.
Example
The following list initializes the unit-valued parameter
NutrientUnit for a particular set of Nutrients.
NutrientUnit := DATA { Energy : [kJ] ,
Protein : [mg] ,
Iron : [%RDA] };
Unit parameters and databases
In addition, AIMMS allows you to read the initial data of a unit parameter from a database table, and write the values of a unit parameter to a database table. The unit values in the database table must be unit constants, and must be stored without square brackets.
Simultaneous unit and data initialization
When a composite table in a data file, or a table in a database contains both the values of a multidimensional unit parameter, and a corresponding numeric parameter whose Unit attribute references that unit parameter, AIMMS allows you to read both identifiers in a single pass. When reading both identifiers, AIMMS will make sure that the numeric values are interpreted with respect to the corresponding unit value that is read simultaneously.
Constant versus parametrized units
AIMMS even allows you to make assignments from identifiers with a constant unit to identifier slices of identifiers with a parametrized unit and vice versa. If AIMMS detects this special situation during compilation of your model, it will postpone the compile unit consistency check whenever necessary, and replace it with a runtime consistency check which is performed every time the assignment is executed. Because all data is stored by AIMMS with respect to atomic units internally, unit consistency again automatically implies scale consistency.
Example
Given the declarations of the previous example, assume the existence of
an additional parameter EnergyContent(f) with a constant associated
unit, say Kcal. Then, AIMMS will postpone the compile unit
consistency check for the following two statements, and replace it with
a runtime check.
NutritiveValue(f,'Energy') := EnergyContent(f);
EnergyContent(f) := NutritiveValue(f,'Energy');
The runtime unit consistency check will only succeed, whenever the unit
value of the unit parameter NutrientUnit('Energy') is commensurate
with the constant unit Kcal.
Restrictions
AIMMS will only replace a compile time with a runtime unit consistency check if a unique unit can be associated with the right-hand side of the assignment at compile time. If the assigned expression consists of subexpressions which have different associated unit expressions at compile time, a compile time error will result. This is even the case when, at runtime, these unit expressions evaluate to units that are commensurate with the unit of the left-hand side of the assignment.
