Declaration of arguments and local identifiers
Specifying arguments
All (formal) arguments of a procedure or function must be specified as a parenthesized, comma-separated, list of non-indexed identifier names. All formal arguments must also be declared as local identifiers in a declaration section local to the procedure or function. These local declarations then specify the further domain and range information of the arguments. If an argument has not been declared when you create (or modify) a procedure or function, AIMMS will open the dialog box illustrated in Fig. 25 which helps you add the appropriate declaration quickly and easily.
Fig. 25 Argument Declaration dialog box
After completing the dialog box, AIMMS will automatically add a declaration section to the procedure or function, and add the arguments displayed in the dialog box to it, as illustrated in Fig. 24.
Input-output type
An important aspect of any argument is its input-output type, which can
be specified by selecting one of the Input
, InOut
, Output
or
Optional
properties in the Argument Declaration dialog box. The
input- output type determines whether any data changes you make to the
formal arguments are passed back to the actual arguments on leaving the
procedure. The precise semantic meaning of each of these properties is
discussed in the AIMMS Language Reference book.
Argument attributes
The choices made in the Argument Declaration dialog box are directly
reflected in the attribute form of the local identifier added to the
model tree by AIMMS. As an example, Fig. 26 shows
the attribute form of the single argument mf
of the procedure
CheckComputableFlow
added in Fig. 25.
In the dialog box of Fig. 25 it is not possible to
modify the dimension of a procedure or function argument directly. If
your procedure or function has a multidimensional argument, you can
specify this with the IndexDomain
attribute of the argument after
the argument has been added as a local identifier to the model tree.
Fig. 26 Declaration form of a procedure argument
Prototype checking
For every call to the procedure or function, AIMMS will verify whether the types of all the actual arguments match the prototypes supplied for the formal arguments, including the supplied index domain and range. For full details about argument declaration refer to the AIMMS Language Reference book.
Local declarations
In addition to arguments, you can also add other local identifiers to declaration sections within procedures and functions. Such local identifiers are only known inside the function or procedure. They are convenient for storing temporary data that is only useful within the context of the procedure or function, and have no global meaning or interpretation.
Not all types supported
Not all identifier types can be declared as local identifiers of a procedure or function, because of the global implications they may have for the AIMMS execution engine. When you try to add a local identifier to a procedure or function, AIMMS will only offer those identifier types that are actually supported within a procedure or function. An example of an identifier type that cannot be declared locally is a constraint.
Not all attributes supported
In addition, for local identifiers, AIMMS may only support a subset of
the attributes that are supported for global identifiers of the same
type. For instance, AIMMS does not allow you to specify a Definition
attribute for local sets and parameters. In the attribute window of
local identifiers such non-supported attributes are automatically
removed when you open the associated attribute form.
