Syntax checking, compilation and execution
Performing a syntax check
Using either Check and commit or Check, commit and close as discussed in Committing attribute changes AIMMS will compile the procedure or function in hand, and point out any syntax error in its body. If you do not want to compile a procedure or function, but still want to commit the changes, you should use the Commit and close button. All edits are ignored when you close the window using the Discard button.
Partial recompilation
Before executing any procedure in your model, AIMMS will automatically verify whether your model needs to be recompiled, either partially or fully. In most cases, there is no need for AIMMS to recompile the entire model after a modification or addition of a new identifier, a procedure or a function. For instance, when you have only changed the body of a procedure, AIMMS needs only to recompile that particular procedure.
Complete recompilation
However, if you change the index domain of an identifier or the number of arguments of a procedure or function, each reference to such an identifier, procedure or function needs to be verified for correctness and possibly changed. In such cases, AIMMS will (automatically) recompile the entire model before any further execution can take place. Depending on the size of your model, complete recompilation may take some time. Note that either partial or complete recompilation will only retain the data of all identifiers present prior to compilation, to the extent possible (data cannot be retained when, for instance, the dimension of an identifier has changed).
Running a procedure
AIMMS supports several methods to initiate procedural model execution. More specifically, you can run procedures
from within another procedure of your model,
from within the graphical user interface by pressing a button, or when changing a particular identifier value, or
by selecting the Run procedure item from the right-mouse menu for any procedure selected in the Model Explorer.
The first two methods of running a procedure are applicable to both developers and end-users. Running a procedure from within the Model Explorer a useful method for testing the correct operation of a newly added or modified procedure.
