Changing the Default Solver
To modify the default solver of a particular type:
Open the Solver Configuration dialog box.
Select the solver you want to use as default.
Click Set default.
By choosing the solver, you will change the default to this solver for all mathematical program types it support, by choosing just one type, you will only change the default to this solver for that specific mathematical program type.
It is also possible to double click an ‘x’ in order to change the default solver.
Changes take effect immediately.
