Drag & Drop in AIMMS Trees
Between the seven available AIMMS tools, drag & drop support is implemented. Drag and drop commands are activated by dragging a node selection from one position in the tree to another position (in the same or even another tree) while holding the left mouse button down.
The available drag & drop features can be divided into the following four categories.
Copy (C) support, indicated in AIMMS by a
cursor. The copy command is activated by holding down the
<Ctrl>
key while dragging.Move (M) support, indicated in AIMMS by a
cursor.
Find (F) support, indicated in AIMMS by a
cursor. The find command is activated by holding down the
<Ctrl>
and<Shift>
key simultaneously while draggingAdd Into (A) support, indicated in AIMMS by a
cursor.
Tips & Tricks
To find all duplicate nodes of a certain node, select the node and drag the node somewhere in the same tree while holding down the
<Ctrl>
and<Shift>
key simultaneously.
The following table describes the availability of drag & drop features between every two AIMMS tools.
tofrom |
ModelExplorer |
Identifier Selector |
PageManager |
TemplateManager |
MenuBuilder |
Model Explorer |
CMF |
A |
F |
F |
F |
F |
CMF |
F |
F |
F |
Page Manager |
CMF |
MF |
F |
Template Manager |
MF |
CMF |
F |
Menu Builder |
F |
F |
CMF |
C copy support
M move support
F find support
A add into support
