Creating Nodes in AIMMS Trees
When you want to add child nodes to a branch, you must first expand the branch. Without expansion, a new node will be inserted directly below the branch, and not as its child node. Expanding an empty branch will result in an empty subtree being displayed. To insert a new node after expansion
  1. Select an existing node below which you want to insert a node.
  2. From the Edit menu, select Insert.
