C Versus FORTRAN conventions
Language conventions
For any external procedure or function you can specify whether the DLL
procedure or function to which the execution is relayed, is written in
C-like languages (such as C and C++) or FORTRAN (see
also Declaration of External Procedures and Functions). For FORTRAN code AIMMS will
make sure that
scalar values are always passed by reference (i.e. as a pointer), and
multidimensional arrays are ordered in a
FORTRAN-compatible manner.
By default, AIMMS will use C conventions when passing arguments to
the DLL procedure or function.
Strings excluded
AIMMS will not directly translate strings into FORTRAN format,
because most FORTRAN compilers use their own particular string
representation. Thus, if you want to pass strings to a FORTRAN
subroutine, you should write your own C interface which converts
C strings into the format appropriate for your FORTRAN compiler.
Array dimensions and ordering
When a multidimensional parameter (or parameter slice) is specified as a
array argument to an external procedure, AIMMS passes an array of
the specified type which is constructed as follows. If the actual
argument has \(n\) remaining (i.e. non-sliced) dimensions of
cardinality \(N_1,\dots,N_n\), respectively, then the associated
values are passed as a (one-dimensional) array of length
\(N_1\cdots N_n\). The value associated with the tuple
\((i_1,\dots,i_n)\) is mapped onto the element
for running indices \(i_j=0,\dots,N_j-1\) (C-style programming).
For Pascal-like languages (with indices running from
\(1,\dots,N\)) all running indices in this formula must be decreased
by 1, and the final result increased by 1. This ordering is compatible
with the C declaration of e.g. the multidimensional array
double arr[\(N_1\)][\(N_2\)]…[\(N_n\)];
Multidimensional example in C
The C function ComputeAverage defined below computes the average
of a 2-dimensional parameter a(i,j) passed as an argument in AIMMS.
DLL_EXPORT(void) ComputeAverage( double *a, int card_i, int card_j, double *average )
{ int i, j;
double sum_a = 0.0;
#define __A(i,j) a[j + i*card_j]
for ( i = 0; i < card_i; i++ )
for ( j = 0; j < card_j; j++ )
sum_a += __A(i,j);
*average = sum_a / (card_i*card_j);
Within your AIMMS model, you can call this procedure via an external
procedure declaration ExternalAverage defined as follows.
ExternalProcedure ExternalAverage {
Arguments : (x,res);
DLLName : "Userfunc.dll";
BodyCall : ComputeAverage(double array: x, card: i, card: j, double scalar: res);
where the argument x and res are declared as
Parameter x {
IndexDomain : (i,j);
Property : Input;
Parameter res {
Property : Output;
FORTRAN array ordering
When you specify the FORTRAN language convention for an external
procedure, AIMMS will order the array passed to the external procedure
such that the tuple \((i_1,\dots,i_n)\) is mapped onto the element
for running indices \(i_j=1,\dots,N_j\). This is compatible with the
default storage of multidimensional arrays in FORTRAN, and allows
you to access such array arguments using the ordinary multidimensional
notation.
Example
Consider a parameter a(i,j), where the index i is associated
with the set {1, 2} and j with the set {1, 2,
3}. When this parameter is passed as a array argument to an
external procedure, the resulting array (as a one-dimensional array with
6 elements) is ordered as follows in the C convention (default).
With the FORTRAN language convention, the ordering is changed as
follows.
