Basic Concepts
Basic concepts
In this section you will find a number of basic concepts that are commonly used in robust optimization. They will help you to unambiguously understand the robust optimization facilities in AIMMS.
The .Robust suffix for variables
Variables can have a .Robust suffix in AIMMS. AIMMS uses the .Robust suffix of variables to store the solution data of a robust optimization model after solving it. AIMMS will create the .Robust suffix for stochastic variables for all variables that are involved in a robust optimization model, including the objective variable.
Robust counterpart
In robust optimization the model with uncertain data is translated into the so-called robust counterpart. Consider the following linear programming problem:
(8)\[\begin{align} \max \{c^{T}x: A^{T}x\leq b\} \tag{P} \end{align}\]
in which \(c\in \mathbb{R}^m\), \(b\in \mathbb{R}^n\) and \(A\in \mathbb{R}^{m\times n}\). Suppose that the actual technology matrix \(A\) is in fact uncertain and it is only known to belong to a bounded uncertainty set \(U_A\subset\mathbb{R}^{m\times n}\). Similarly assume that right hand side \(b\) belongs to an uncertainty set \(U_b\subset\mathbb{R}^n\), and the objective coefficients \(c\) to an uncertainty set \(U_c\subset\mathbb{R}^m\). The robust counterpart (9) for the nominal problem (8) is then defined as follows:
(9)\[\begin{align} \max \{c^{T}x:A^{T}x\leq b,\,\forall A\in U_A, c\in U_c, b\in U_b\}. \tag{RC} \end{align}\]
Uncertainty set
The sets \(U_A\), \(U_c\) and \(U_b\) specify all possible realizations of the uncertain data and are collectively called the uncertainty set. The main questions associated with the uncertainty set are:
  • When and how can the robust counterpart of an uncertain problem be reformulated as a computationally tractable optimization problem?
  • How to specify a reasonable uncertainty set, i.e., meaningful for a particular application and yielding a tractable robust counterpart?
It can be shown that when the uncertainty set is a multi-dimensional interval or described by linear constraints, then the robust counterpart can be reformulated as a linear problem. Furthermore, when the uncertainty set is an ellipsoid, then the robust counterpart is still tractable, i.e., it can be reformulated as a second-order cone program (SOCP), for which efficient (polynomial time) solution methods exist. The reformulation of the robust counterpart is an automated process performed by AIMMS during the generation of your mathematical program.
Integer programming
If the uncertainty set is a multi-dimensional interval or described by linear constraints, then the robust counterpart of a mixed-integer robust optimization problem can also be reformulated as a mixed-integer optimization problem. If the uncertainty set is described by ellipsoidal constraints then the robust counterpart becomes a mixed-integer second-order cone program. This class of problems is more difficult to solve than mixed-integer optimization problems.
Scenarios
A special situation to consider is when the uncertainty set consists of a finite number of points representing a collection of scenarios. This discrete case resembles the situation in multi-stage stochastic programming with discrete data realizations. More precisely, in this case hard constraints are imposed for every scenario \(s\), while the objective is to optimize a worst-case performance measure with respect to the set of scenarios. This performance measure can be, for example, the objective value of the original (deterministic) model associated with an uncertain scenario. Another possibility is to define this performance measure as a deviation of the objective for a decision with respect to the absolutely optimal objective for each scenario. In the latter case, the optimal robust solution will be the one with the minimum maximum deviation across scenarios.
Chance constraints
Another manner to account for uncertainty into your model is by specifying so-called chance constraints. In order to introduce chance constraints, you have to declare some of the parameters in your model to take random values from a distribution with given characteristics. Subsequently, you can specify that some of the constraints in your model be satisfied with a given probability with respect to the specified data distributions. For example, if a chance constraint has a probability of 95%, this means that the constraint should be satisified for (at least) 95% of the realizations drawn from specified distributions of the random parameters contained in it. Compared to using uncertain parameters, specifying random parameters with the same range and formulating the existing constraints as chance constraints may lead to solutions that put less emphasis on worst-case scenarios that only occur occasionally.
Multistage optimization
All decision variables in problem (8) represent “here and now” decisions; they get specific numerical values as a result of solving the problem before the actual data “reveals itself” and as such are independent of the actual values of the data. There are situations where this is too restrictive, since “in reality” some of the decision variables can adjust themselves, to some extent, to the true values of the uncertain data.
Adjustable variables
For that reason, it is possible to specify both non-adjustable and adjustable variables in AIMMS, similar to first-stage and second-stage (or multi-stage) decisions in stochastic programming, where the solution of a variable in stage \(n\) depends on the specific solution of variables in stage \(n-1\) in a scenario-dependent manner. Please note that, while non-adjustable variables can be integer, adjustable variables must be continuous.
Basic procedure for solving robust optimization models
The implementation of robust optimization in AIMMS closely follows the concepts described in this section. The basic procedure to create and solve a robust optimization model in AIMMS is as follows:
  • indicate in your model which parameters are to become uncertain or random,
  • for every constraint in your model that you want to become a chance constraint, specify the probability with which it must hold,
  • for every adjustable variable in your model specify on which uncertain parameters it depends, and
  • specify possible realizations of the uncertain parameters in terms of predefined regions or using specialized uncertainty constraints.
Each of these steps is explained in more detail in the sections to follow. Note that changing parameters, variables and constraints in your model into uncertain or random parameters, adjustable variables and chance constraints does in no way influence the possibility to solve the underlying deterministic model in its original form. Thus, the robust optimization facilities in AIMMS always form a true extension of the functionality of the existing AIMMS application. It is even possible to extend an existing deterministic model to both a stochastic model and a robust optimization model, all of which can be solved independently.
