The AIMMS Command Line Tool
AIMMS command line tool
Next to accessing AIMMS from within your own programs through the AIMMS component technologies, AIMMS also supports a command line tool through which you can control an AIMMS project externally. You can start the AIMMS command line tool by running
AimmsCmdproject-path
The AimmsCmd program is located in the Bin directory of your
AIMMS installation.
Commands
The AIMMS command line tool offers commands to
assign values to sets, and to scalar and multidimensional identifier slices,
display the contents of sets, and the values of scalar and multidimensional identifier slices,
empty sets or multidimensional identifier slices,
retrieve the cardinality of sets or multidimensional identifier slices,
run procedures,
execute system commands, and
close the AIMMS project and quit the program.
Each command is terminated by a semicolon.
Assignments
You can assign a value to sets and multidimensional identifiers and slices thereof through one of the commands
Letreference:=data-expression;Letreference+=data-expression;
where the := operator refers to completely replacing the contents of
reference and the += operator refers to a merge operation.
References
A reference in an assignment is either
an identifier name such as “
Transport”, ora reference to an identifier slice such as
Transport('Amsterdam',j)where each sliced dimension must refer to a quoted set element.
Data expressions
The data expressions allowed in an assignment are
a set expression preceded by the keyword
Setas inSet {'Amsterdam', 'Rotterdam'}where all set elements must be quoted,
a ranged integer set preceded by the keyword
Setas inSet {1 .. 10}a scalar numeric, element or string value as in
1011.7'an element'"a string"a tuple list of numeric, element or string values preceded by the keyword
Listas inList {('Amsterdam','Paris') : 10, ('Paris','London') : 20}Listkeyword may be optionally preceded by the keywordStrict. In this case using an element name not present in the domain set will trigger an error (it will be added automatically to the domain set otherwise),a dense multidimensional array of numeric, element or string values preceded by the keyword
Arrayas inArray [[1,2],[3,4],[5,6]]
Value display
You can request AIMMS to display the contents of sets and multidimensional identifier slices in your model through the command
Displayreference [:precision] [as Array];
For multidimensional identifier data AIMMS will, by default, use the
List format described above. Through the optional “as Array”
clause you can instruct AIMMS to display the identifier data as a dense
array.
Empty identifiers
To empty the data of sets and multidimensional identifier slices in your model you can use the command
Emptyreference;
Identifier cardinality
You can request AIMMS to retrieve the cardinality of sets and multidimensional identifier slices in your model through the command
Cardreference;
Run procedures
With the command
Runprocedure-name;
you can request AIMMS to run a procedure (without arguments). When finished, AIMMS will display the return value of the procedure.
Executing system commands
You can let AIMMS execute a system command through the command
Systemsystem-command;
where system-command is a string to be executed by command shell.
Help
Through the Help command, a list with a brief description all
available commands will be displayed.
Closing the project
You can close the AIMMS project and quit the command line tool through the command
Quit;
