Introduction and motivation
Unforeseen surprises …
Even though you have taken the utmost care in constructing your linear optimization model, there are often unforeseen surprises that force you to take a further look at the particular generated model at hand. Why is the model infeasible or unbounded? Why is the objective function value so much different from what you were expecting? Are the individual constraints generated as intended? Why is the number of individual constraints so large? Why are the observed shadow prices so unrealistically high (or low)? These and several other related questions about the matrix and the solution need further investigation.
… are not easily explained
The answer to many model validation questions is not easily discovered, especially when the underlying optimization model has a large number of individual constraints and variables. The amount of information to be examined is often daunting, and an answer to a question usually requires extensive analysis involving several steps. The functionality of the math program inspector is designed to facilitate such analysis.
Some of the causes
There are many causes of unforeseen surprises that have been observed in practice. Several are related to the values in the matrix. Matrix input coefficients may be incorrect due to a wrong sign, a typing error, an incorrect unit of measurement, or a calculation flaw. Bounds on variables may have been omitted unintentionally. Other causes are related to structural information. The direction of a constraint may be accidentally misspecified. The subsets of constraints and variables may contain incorrect elements causing either missing blocks of constraints and variables, or unwanted blocks. Even if the blocks are the correct ones, their index domain restrictions may be missing or incorrect. As a result, the model may contain unwanted and/or missing constraints and/or variables.
Purpose
The purpose of the mathematical program inspector included in AIMMS is to provide you with
  • insight into the (structure of the) generated model and its solution (if present), and
  • a collection of tools to help you discover errors in your model ,
