Run-Only
- Long Name
--run-only
- Short Name
-R
- Argument
Procedure name
When you want to run an AIMMS project unattended, you can call AIMMS with the --run-only option. This option expects the name of a procedure in the model, which will be executed after the project is opened. After running the procedure, the AIMMS session will be terminated. You can only specify the --run-only option if you also specify a project file on the commandline. Note that actions upon open project, such as load a case, open a page, execute a procedure, are not performed in run-only mode. MainTermination is executed.
