Startup Bitmap
When you startup AIMMS a standard splash screen is displayed. If you startup AIMMS with your project as a command line argument, then you can replace this standard AIMMS splash screen with your own splash screen. To achieve this you should create a bitmap file that contains your own splash screen and save this bitmap as <project-name>.bmp in the project directory.
The project specific splash screen is only shown at startup of AIMMS and not if you open the project using the Open Project command from the File menu
