Reducing the Number of Elements
Application phases
In general, one can divide an application in three phases:
reading input data, often referred to as reading and preprocessing,
processing data, often referred to as the core model, and
writing output results, often referred to as reporting.
Interactive applications add the on/off switching of various application features, the setting of tuning parameters, the consideration of various scenarios, the output to screen, and so on. This does not change the basic concept, however. It only means that the inputs come from various sources and the outputs go to various destinations. An important observation is that, usually, most of the computation time is spent in the core model as this involves:
the execution of assignments,
the evaluation of definitions,
the generation of constraints, and
the execution of one or more
SOLVEstatements.
Reducing the core model
Obviously, the fewer data we have in the core model, the sooner we’re finished. Often, a considerable percentage of the data read in during the data input phase is irrelevant to the final result. We could, therefore, consider spending more time in the data input phase and try to remove such irrelevant data with the primary objective of reducing the amount of data used in the core model. Experience shows that this effort is usually, but not always, worthwhile.
Reducing the number of elements
In this section, two complementary methods of reducing the model size are considered, namely reducing the number of elements in
one-dimensional sets, and
multidimensional identifiers.
Size Reduction of One-Dimensional Sets
Two approaches
If, after the data input phase, a one-dimensional set contains a large number of elements that are irrelevant to the core model, there are two possible approaches to removing them from computations in the core model. These are:
adding a condition to all identifiers indexed over that set, or
introducing a subset of active elements, and using an index to that active subset.
These two approaches are illustrated below.
Tanks example
As a running example, consider a collection of tanks. Let us introduce a few identifiers related to tanks:
Set Periods {
Index : t;
Set Tanks {
Index : Tnks;
Set BrokenTanks {
SubsetOf : Tanks;
Parameter StrategicReserve {
IndexDomain : Tnks;
Parameter SizeOfTank {
IndexDomain : Tnks;
Parameter TankIsRelevant {
IndexDomain : Tnks;
Range : binary;
Definition : {
1 $ [ ( not Tnks in BrokenTanks ) AND
( SizeOfTank( Tnks ) > StrategicReserve( Tnks ) ) ]
Variable TankLevel {
IndexDomain : (t,Tnks) | TanksIsRelevant( Tnks );
Constraint TankLimit {
Definition : TankLevel( t,Tnks ) <= SizeOfTank( Tnks );
The example above illustrates the first approach, in which the
restriction on the tanks is embodied by the parameter
TankIsRelevant.
Introducing active subsets
To illustrate the second approach, we change the above model section by
introducing the active subset ActiveTanks and modifying the
declaration of the variable TankLevel and the constraint
TankLimit as presented below.
Set ActiveTanks {
SubsetOf : Tanks;
Index : tnk, tnk2;
Definition : { Tnks | TankIsRelevant(Tnks) };
IndexDomain : (t,tnk);
Definition : TankLevel( t,tnk ) <= SizeOfTank( tnk );
The core model still consists of the variable TankLevel and the
constraint TankLimit but their index domain has been changed. These
identifiers are now declared over active tanks only. Because of this
change in the index domain, the parameter TankIsRelevant is no
longer needed in their index domain condition.
Speedup by active subsets
One may argue that nothing is gained because the selection through
TankIsRelevant is now replaced by the index tnk of the active
subset ActiveTanks. However, the AIMMS execution engine has been
tuned to select relevant elements of parameters and variables through
indices in subsets. The selection via a condition such as
TankIsRelevant(Tnks) will force AIMMS to retrieve the values for:
the parameter or variable at hand,
the parameter
TanksIsRelevant, and thencombine these values using the ‘such that’ operator
Both approaches produce identical results and limit the core model
execution to relevant elements only. The first approach using the
TankIsRelevant condition takes more execution time than the second
approach using an index in the active subset ActiveTanks because
this latter approach selects the relevant elements more directly.
Multiple active subsets
Intuitively you might expect the improvement to be minor because probably only a few tanks, if any, are removed from the collection of all tanks. However, for other indices of the model the gain may be significant. More significant gains may be observed, for example, when
you study a few periods from a large model calendar,
you study a few scenarios from a large database of scenarios,
you study a rather limited region,
there are only a few crudes available from a large collection of available crudes, or
there are only a few products ordered from a large catalog.
A large dimensional identifier, indexed over multiple active subsets, will have the effect.
Starting with a core model
What if your model does not limit the number of elements in one-dimensional sets at all? Following the active subset approach, as illustrated above, you will have to modify the core model wherever you use the root set or an index in the root set. In such a situation, you can also implement “active subsets” by introducing a superset of the root set, and letting the original root set take on the role of an active subset.
Example
We continue the running example by presenting a core model version of it.
Set Periods {
Index : t;
Set Tanks {
Index : tnk;
IndexDomain : tnk;
In implementing the active subset approach, we introduce a new superset
AllTanks and redefine the original set Tanks as an active subset
of the superset AllTanks as follows.
Set AllTanks {
Index : Tnks;
Set BrokenTanks {
SubsetOf : AllTanks;
IndexDomain : Tnks;
IndexDomain : Tnks;
Range : binary;
Definition : {
Set Tanks {
Index : tnk;
IndexDomain : Tnks;
Comment : Now Wrt AllTanks instead of Tankss}
Note that the variable and constraint declarations in the core model
above have not been altered, but their size has been reduced by the size
reduction in the set Tanks.
Size Reduction of Multidimensional Identifiers
Limiting multidimensional identifiers
Having illustrated limiting the number of elements in one-dimensional
sets, we want to consider limiting the number of elements in
multidimensional parameters, variables, and constraints. The AIMMS
language facilitates this through the IndexDomain attribute.
Index domain conditions
Domain conditions can be specified in the IndexDomain attribute of
multidimensional parameters, variables, and constraints. Whenever such
an identifier is assigned, generated, or referenced in an expression,
AIMMS will automatically add the domain condition so keeping your
assignments and constraints more concise and efficient.
Continued example
We illustrate this by extending the above example as follows.
Variable Flow {
IndexDomain : (t,tnk,tnk2);
Constraint TankLevelBalance {
IndexDomain : (t,tnk) | t <> first(Periods);
Definition : {
TankLevel(t-1,tnk) ! Level of previous period
- Sum( tnk2, Flow(t,tnk,tnk2) ) ! Flow out of the tank
+ Sum( tnk2, Flow(t,tnk2,tnk) ) ! Flow in to the tank
= TankLevel(t,tnk) ! Current level
Comment : {
"Level at end of previous period
minus outflow
plus inflow is
level at end of current period"
Note that, using this formulation, AIMMS generates matrix columns for
every possible pair of tanks, whereas in practice only a small selection
can have an actual flow. If this selection of possible connections
between tanks is represented by a relation TankConnections, the
constraint TankLevelBalance could be written more efficiently as:
Set TankConnections {
SubsetOf : (AllTanks, AllTanks);
Variable Flow {
Definition : {
TankLevel(t-1,tnk)
- Sum( tnk2 | (tnk,tnk2) in TankConnections, Flow(t,tnk,tnk2) )
+ Sum( tnk2 | (tnk2,tnk) in TankConnections, Flow(t,tnk2,tnk) )
= TankLevel(t,tnk)
Note the repetition of the condition in the above formulation. This is
because the condition is actually a restriction on the Flow
variable, and should therefor be a part of its declaration. This leads
to a much more concise formulation, as presented below.
Variable Flow {
IndexDomain : (t,tnk,tnk2) | (tnk,tnk2) in TankConnections;
Definition : {
TankLevel(t-1,tnk)
= TankLevel(t,tnk)
Using binary parameters
A frequently observed alternative to using relations is the use of binary parameters. The above example could then be written as follows:
Parameter TankIsConnected {
IndexDomain : (tnk,tnk2);
Range : {0, 1};
Variable Flow {
IndexDomain : (t,tnk,tnk2) | TankIsConnected(tnk,tnk2);
The outflow term of TankLevelBalance will then be generated as if it
were written:
Sum( tnk2, Flow(t,tnk,tnk2) $ TankIsConnected(tnk,tnk2) )
The notation using binary parameters is equivalent to that with relations. Which option you use is only a matter of taste and style.
Why use index domain conditions?
We would encourage you to employ index domain conditions, as using them has the following advantages:
Index domain conditions speed up the execution because:
They exclude irrelevant elements in assignments to parameters with an index domain condition,
Having index domain conditions on variables effectively makes the referencing of such variables sparse, as only relevant columns are generated, and
Index domain conditions on a constraint avoid the generation of irrelevant rows of that constraint.
Index domain conditions permits concise formulations. As illustrated above, you do not need to include the domain condition of the
Flowvariables while constructing theTankLevelBalanceconstraint. Moreover, you do not need to worry that you mightforget such a condition at a particular place in the model.Whenever you determine a more restrictive condition on an identifier
A, you only need to change your model at one place, namely in the index domain condition of that identifierA. You don’t need to go through the entire model changing every reference to the identifierA.
Tight conditions
To make index domain conditions as effective as possible, they should remove all, or almost all, irrelevant combinations. Constructing such “tight” index domain conditions, can be far from straightforward. However, the time spent on constructing tight index domain conditions often pays off with a significant reduction in the total execution time of your model.
