Execution Efficiency Cookbook
This chapter
Typically, when you start running your model with realistic, large-scale data sets, execution performance becomes an important issue. In this chapter, we discuss various techniques that you can use to improve the execution efficiency of your model.
Dividing the time spent
The running time of AIMMS applications can be divided in the time spent by AIMMS itself and the time spent by the solution algorithms (i.e. solvers) used by AIMMS.
Time spent by solvers
The time used by the solvers mostly depends, apart from the quality of the solver, on the specific formulation of the mathematical program to be solved. Finding a formulation that can be efficiently solved is often a challenging task and is beyond the scope of this chapter. For a detailed discussion, you are referred to the extensive literature that exists on this subject.
Time spent by AIMMS
AIMMS itself typically spends most of its time on the execution of assignment statements and the generation of constraints. This time depends on several factors. A few of these factors are:
the size of the sets and the data set size used in your model,
the efficiency of the AIMMS execution engine, and
the language constructs used to formulate the execution statements and constraints.
Understanding AIMMS execution
At AIMMS we are committed to continuously improving the efficiency of the AIMMS execution engine and the AIMMS matrix generator. The efficiency of your application, however, does not only depend on the efficiency of AIMMS, but also on the specific formulation of your model and the language constructs that you have used. A global understanding of the AIMMS execution engine, as presented in The AIMMS Sparse Execution Engine, may provide a good background on which to start reconsidering particular formulations that lead to bottlenecks in execution performance in your application.
Analysis tools
In addition, AIMMS provides you with two tools for analyzing execution bottlenecks, namely the Identifier Cardinalities and Profiler tools. The use of both tools is described in Debugging and Profiling an AIMMS Model.
Analyzing cardinalities
The Identifier Cardinalities tool can help you to discover identifiers with a large number of elements. Such identifiers, when used in statements and constraints, may lead to efficiency bottlenecks throughout your model. Whenever you are able to reduce the number of elements associated with such identifiers, by leaving out irrelevant elements, the execution efficiency of your model will improve at several places. Naturally, such reductions are not possible when all the elements are relevant to the computation of the solution. In Reducing the Number of Elements, we discuss two frequently observed and effective approaches to reducing the number of elements in both one-dimensional sets and multidimensional identifiers.
Analyzing statements
With the AIMMS Profiler tool you can identify the individual statements and constraints on which the AIMMS execution engine spends most of its time. Even if the inefficiencies are not the result of superfluous identifier cardinalities, it may still be possible to review and rewrite such statements and constraints in order to improve the execution efficiency of your application. In Analyzing and Tuning Statements we discuss potential bottlenecks and alternative formulations for particular statements and constraints.
Simple precautions
Before you begin tuning your application, you may want to set aside a
copy of the application and inputs with known results. You can then set
up a script that executes each of these tests using the AIMMS command
line option --run-only (see also Calling Aimms).
In addition, you may wish to regularly commit your
sources to a version control system in order to track the changes you
make over time.
