AIMMS to ODH Mapping
ODH engine options
The table below shows in the left column the AIMMS options that control the ODH engine; the right column displays for each AIMMS options the associated ODH-CPLEX parameter.
Option name in AIMMS  |
Name in ODH-CPLEX  |
MAXBACKTRACK  |
DECOMPDENSITY  |
GLOBALBOUNDS  |
INTERDIV  |
DIVISOR  |
MAXREPEAT  |
MAXINFREPEAT  |
MAXINTERDIV  |
FEASOPT  |
VARIABLECLEAN  |
OBJTARGET  |
FEASTOL  |
ODHPRESOLVE  |
SEED  |
PRESOLVE  |
QUICKFIRSTSOLVE  |
REJECTINFSOL  |
RELAXSOS2  |
PHASE12  |
WRITESOLUTION  |
FIRSTFEAS  |
FIRSTFEASCONTINUE  |
FIRSTFEASEFFORT  |
FIRSTFEASSHIFT  |
RECURSE  |
RECURSEDECOMP  |
RECURSEITERLIM  |
RECURSESOLITERLIM  |
RECURSEMINITERLIM  |
DETERMINISTIC  |
PENALTY  |
STRATEGY  |
RECURSELOG  |
THREADLOG  |
THREADS  |
SYNCFREQ  |
PROCESSORLOCK  |
CPLEX solve options
The two tables below show options used by ODH-CPLEX for the main CPLEX solve in ODH-CPLEX (if the Search Mode is set to ‘Global Solution’) or for getting an initial feasible solution (if the Search Mode is set to ‘Local Solution’).
Name in ODH-CPLEX for main CPLEX solve  |
CPX_BARALG  |
CPX_BAREPCOMP  |
CPX_BARCROSSALG  |
CPX_BARCOLNZ  |
CPX_BARGROWTH  |
CPX_BARITLIM  |
CPX_BARMAXCOR  |
CPX_BAROBJRNG  |
CPX_BARORDER  |
CPX_BARSTARTALG  |
CPX_ADVIND  |
CPX_CLOCKTYPE  |
CPX_CONFLICTALG  |
CPX_DATACHECK  |
CPX_DETTILIM  |
CPX_MEMORYEMPHASIS  |
CPX_NUMERICALEMPHASIS  |
CPX_RANDOMSEED  |
CPX_SCAIND  |
CPX_SIFTALG  |
CPX_BARDISPLAY  |
CPX_CLONELOG  |
CPX_MIPDISPLAY  |
CPX_MIPINTERVAL  |
CPX_SIMDISPLAY  |
CPX_BTTOL  |
CPX_BRDIR  |
CPX_OBJDIF  |
CPX_EPINT  |
CPX_NODELIM  |
CPX_STRONGCANDLIM  |
CPX_DIVETYPE  |
CPX_MIPEMPHASIS  |
CPX_SUBALG  |
CPX_PROBE  |
CPX_MIPSEARCH  |
CPX_STARTALG  |
CPX_TRELIM  |
CPX_NODEFILEIND  |
CPX_PRESLVND  |
CPX_STRONGTHREADLIM  |
CPX_REPAIRTRIES  |
CPX_STRONGITLIM  |
CPX_MIPORDIND  |
CPX_MIPORDTYPE  |
CPX_PROBETIME  |
CPX_PROBEDETTIME  |
CPX_RELOBJDIF  |
CPX_VARSEL  |
CPX_NODESEL  |
CPX_WORKMEM  |
CPX_SUBMIPNODELIMIT  |
CPX_SUBMIPSCAIND  |
CPX_SUBMIPSTARTALG  |
CPX_SUBMIPSUBALG  |
CPX_BQPCUTS  |
CPX_CLIQUES  |
CPX_COVERS  |
CPX_AGGCUTLIM  |
CPX_EACHCUTLIM  |
CPX_CUTSFACTOR  |
CPX_DISJCUTS  |
CPX_FLOWCOVERS  |
CPX_FLOWPATHS  |
CPX_FRACCUTS  |
CPX_FRACCAND  |
CPX_FRACPASS  |
CPX_GUBCOVERS  |
CPX_IMPLBD  |
CPX_LANDPCUTS  |
CPX_LOCALIMPLBD  |
CPX_MCFCUTS  |
CPX_CUTPASS  |
CPX_MIRCUTS  |
CPX_NODECUTS  |
CPX_RLTCUTS  |
CPX_ZEROHALFCUTS  |
CPX_FPHEUR  |
CPX_HEUREFFORT  |
CPX_HEURFREQ  |
CPX_LBHEUR  |
CPX_RINSHEUR  |
CPX_BNDSTRENIND  |
CPX_COEREDIND  |
CPX_SYMMETRY  |
CPX_RELAXPREIND  |
CPX_REPEATPRESOLVE  |
CPX_SOS1REFORM  |
CPX_SOS2REFORM  |
CPX_POLISHAFTEREPAGAP  |
CPX_POLISHAFTERNODE  |
CPX_POLISHAFTERINTSOL  |
CPX_POLISHAFTEREPGAP  |
CPX_POLISHAFTERTIME  |
CPX_POLISHAFTERDETTIME  |
CPX_SOLNPOOLAGAP  |
CPX_SOLNPOOLCAPACITY  |
CPX_SOLNPOOLINTENSITY  |
CPX_SOLNPOOLGAP  |
CPX_SOLNPOOLREPLACE  |
CPX_POPULATELIM  |
CPX_NETEPRHS  |
CPX_NETITLIM  |
CPX_NETEPOPT  |
CPX_NETPPRIIND  |
CPX_AUXROOTTHREADS  |
CPX_THREADS  |
CPX_PARALLELMODE  |
CPX_AGGIND  |
CPX_DEPIND  |
CPX_FOLDING  |
CPX_AGGFILL  |
CPX_PREPASS  |
CPX_REDUCE  |
CPX_PREDUAL  |
CPX_QPMAKEPSDIND  |
CPX_BARQCPEPCOMP  |
CPX_MIQCPSTRAT  |
CPX_QTOLININD  |
CPX_QPMETHOD  |
CPX_QPNZREADLIM  |
CPX_OPTIMALITYTARGET  |
CPX_CRAIND  |
CPX_DPRIIND  |
CPX_DYNAMICROWS  |
CPX_EPRHS  |
CPX_EPMRK  |
CPX_EPOPT  |
CPX_EPPER  |
CPX_PERIND  |
CPX_PRICELIM  |
CPX_PPRIIND  |
CPX_REINV  |
CPX_SIFTSIM  |
CPX_SINGLIM  |
CPX_PERLIM  |
The table below shows Solvers General options that are mapped to ODH-CPLEX parameters.
Name in ODH-CPLEX  |
CPX_CUTLO  |
CPX_CUTUP  |
CPX_INTSOLLIM  |
CPX_EPAGAP  |
CPX_EPGAP  |
CPX_ITLIM  |
TIMELIMIT  |
Heuristic sub-model options
The heuristic sub-model parameters can only be set using a Parameter File. The syntax for the parameters that influence the heuristic sub-model CPLEX solves is the following: SUB_<parameter> where <parameter> refers to the ODH-CPLEX name in the second table above. The syntax for the parameters that influence the heuristic sub-model CPLEX solves in Phase I is the following: PHASE1_<parameter>.
For example, SUB_CPX_RINSHEUR specifies the RINS heuristic frequency for CPLEX if it used to solve a heuristic sub-model, while PHASE1_CPX_RINSHEUR specifies the RINS heuristic frequency for CPLEX if it used to solve a heuristic sub-model in Phase I.
Learn more about
