MACRO Declaration and Attributes
Macro facility
The MACRO facility offers a mechanism for parameterizing
expressions. Macros are useful for enhancing the readability of models,
and avoiding inconsistencies in frequently used expressions.
Declaration and attributes
Macros are declared as ordinary identifiers in your model. They can have
arguments. The attributes of a Macro declaration are listed in
this table.
Attribute |
Value-type |
See also page |
string |
argument-list |
comment string |
expression |
The Definition attribute
The Definiton attribute of a macro declaration is the replacement
text that is substituted when a macro is used in the model text. The
(optional) Arguments of a macro must be scalar entities. Unlike
function arguments, however, you do not have to declare Macro
arguments as local identifiers. The Definition of a macro must be a
valid expression in its arguments.
Example
When you define a macro with arguments, the actual replacement text depends on the arguments that are supplied to it, as illustrated in the following example. Using the macro declaration
Macro MyAverage {
Arguments : (dom, expr);
Definition : Sum(dom, expr) / Count(dom);
the assignments
AverageTransport := MyAverage( (i,j), Transport(i,j) );
AverageNZTransport := MyAverage( (i,j) | Transport(i,j), Transport(i,j) );
are compiled as if they read:
AverageTransport := Sum( (i,j), Transport(i,j) ) / Count( (i,j) );
Sum ( (i,j) | Transport(i,j), Transport(i,j) ) /
Count( (i,j) | Transport(i,j) );
Expression substitution
When you use a macro with arguments, the actual arguments must be
valid expressions. As a result, there is no need to add additional
braces to the replacement text of the macro, like, for instance, in the
C programming language. The following example illustrates this
point.
Macro MyMult {
Arguments : (x,y);
Definition : x*y;
Using this macro, the expression
a + MyMult(b+c,d+e) + f
will evaluate to
a + ((b+c)*(d+ e)) + f
instead of
a + b + c*d + e + f
Macro versus defined parameters
In many execution statements you have a choice to use either macros or defined parameters as a mechanism to replace complicated expressions by descriptive names. While a macro is purely substituted by its replacement text, the current value of a defined parameter is stored and looked up when needed. When deciding whether to use a macro or a defined parameter, you should consider both storage and computational consequences. Macros are recomputed every time they are referenced, and therefore there may be an unnecessary time penalty if the macro is called with identical arguments in more than one place within your model. When storage considerations are important, a macro may be attractive since it does not introduce additional parameters.
Macro versus defined variables
You should also consider your choices when you use a macro with
variables as arguments in a constraint. In this case, you also have the
option to use a defined variable, or a defined Inline variable (see
also Variable Declaration and Attributes). The following considerations are of interest.
A macro can produce different expressions of the same structure for different identifier arguments, but does not allow you to specify a domain restriction that will reduce the number of generated columns in the matrix.
Defined and
Inlinevariables support an index domain to restrict the number of generated columns, but only allow an expression in terms of fixed identifiers. Compared to a macro or anInlinevariable, the number of rows and columns increases for a defined variable, but if the variable is referenced more than once in the other constraints, it will result in a smaller number of nonzeros.An advantage of variables (both defined and
Inline) over macros is that their final values are stored by AIMMS, and can be retrieved in other execution statements or in the graphical user interface, whereas a macro has to be recomputed all the time.
